Brian23
Hi, I have a 2005 E200 Estate and an advisory on my MoT says:- Off side front Ball Joint Slight Play (rear lower arm ball joint movement). Do I need any special tools, apart from joint separator?
A breaker bar , and a torque wrench and you should be good to go (for whatever is at the other end of the ball joint )Hi, I have a 2005 E200 Estate and an advisory on my MoT says:- Off side front Ball Joint Slight Play (rear lower arm ball joint movement). Do I need any special tools, apart from joint separator?
Joint separator which you already haveand to actually remove the joint from car?
Assuming your just replacing the rubber, then you will need a puller and a press. Replacing the rubber is cheaper that the entire link holding the rubber, but that depends on the condition of the link and the nuts etc.
Lemforder are OE for many suspension parts on mercs, you may be able to see thier stamp on the link or a part number, google it and you may find the OE manifacturer
I am a bit cofused now. I am asking about a ball joint removal. Looking on line I think that you need a press to push out and push in the ball joint unit. I will have to take a look and see. Probably te option I should have taken first.
You mean a bush rather than a ball joint ? The ball joint is just split with the ball joint separator then falls outI am a bit cofused now. I am asking about a ball joint removal. Looking on line I think that you need a press to push out and push in the ball joint unit. I will have to take a look and see. Probably te option I should have taken first.
The front is a ball joint splitter tool , which you have . Rear I don’t knowI can only go by what is on the MoT certificate which says:- Off side front Ball Joint Slight Play (rear lower arm ball joint movement).
There's obviously some confusion as to what's got the play in it. The bottom ball joint does appear to be part & parcel of a bush & is pressed into the lower arm.
