does it sound like my "kick-down" cable needs replacing/adjusting?
monkey1983
This is my original post..Bought an e240 1998 76k about 6 weeks ago.
Over last 2-3 weeks when you put your foot down, the revs increase but it doesnt change gear until you release your foot off accelerator... also, when stop on a steep hill it will not hold unless you apply brake - starts rolling back!
just had gearbox fluid checked - level etc is fine...
Anyone any ideas? - man said to just run it til it breaks???? as needs seals replacing - anyone any idea how much this will cost?
Anyone you can recommend in west yorkshire area?
After doing some reading, I m just wondering if it could be the kick-down cable needs tightening/replacing?
It ll be thurs before I can get to garage so any advice would be fab?
Anyone got rough costs of ;
new MAF fitting or new cable fitting/adjusting?
roofless
w124 e220 estate
even if the fluid level is ok it might need a new gearbox fillter if you have the history of the car it might say if it was done poss at 40k i had the same prob had to lift a bit to change to fourth i did mine d.i.y easy but dirty now its smooth as silk
star
Reading
Smart + others :)
Same answer as before (22nd), no cable fitted to this model. report back once you have tried/borrowed an air mass
david raptor
s wales newport
i did not want to start a new post so il ask in here i have just bought a Mercedes C250 TD Elegance 4dr Auto [5] and i the kick down dont work at all say if you are doing 50 mph and put you foot down hard it dose not change down a gear .where would i start looking to fix the problem many thanks dave
M
monkey1983
Update
As advised had the MAF checked and cleaned as didnt have access to borrow one. Car drives much more smoothly and feels better but kick-down still not as it should be?
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Dave, if your kick down is not working at all I would suggest you look at the switch under the accelerator pedal first ,shown at No.53 here; http://www.detali.ru/cat/oem_mb2.as...GM=717.460&CT=F&cat=44V&SID=54&SGR=640&SGN=20 .
roofless
w124 e220 estate
If Its Holding In A Gear Say From 3rd To 4th Longer Than You Exspect Its Not The Kick Down .
roofless
w124 e220 estate
fist thing check the fluid level then have a look at the switch on the floor under the accelerator pedal for basic function or damage even obstruction is the pedal pressing the switch
star
Reading
Smart + others :)
cleaning doesn't always work.
davidsl500
