John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
I have a dent in the middle section of the driver's door, about 4-5cms in from rear edge of door, in line with below the door handle, and just above the plastic lower section (1995 300 Diesel Estate). Before taking the door card off and other parts to pieces (probably accompanied by broken clips, skinned knuckles, and much bad language) does anyone here know whether I am likely to get behind this dent, or whether a double skin, strengthening bars or other structures will be in the way? The dent is one of those annoying supermarket car park jobs - small (less than 10p coin in size and has not broken paint) but no doubt expensive to repair at a body shop! I have a panel hammer and a block of wood for outer surface, and some skill, but I do not want to pull everything apart if I have no chance of getting a clear access behind it. I am sure somebody here has been in there on W124!
John
John
