Door mirror/reverse gear
Discussion in 'General Mercedes-Benz Related Discussion' started by EmilysDad, Mar 14, 2019 at 7:34 PM.
  1. EmilysDad
    EmilysDad Senior Member
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    I'm away at the moment so can't RTFM :)
    It's come on before but assumed that some how I'd caught the button ....
    When I select reverse gear, the light for the adjusting driver's side door mirror lights up ..... :confused: :confused:
    Confused ..... ;)
  2. keefysher
    keefysher Senior Member
    2,681
    875
    May 4, 2007
    Hampshire
    Your Mercedes:
    W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
    Your online manual is here:
    https://moba.i.daimler.com/baix/cars/w166/en_GB/index.html#emotions/Startseite.html
    The light means you have set the dip function on the door mirror when you select reverse. You can set either or both door mirrors to dip on engaging reverse. You turn the ignition on, not start. Push button for which mirror, select reverse, then adjust dip position, release button and put out of gear, turn off, its set
  3. OP
    EmilysDad
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Ah! Thanks for that ..... I'd a feeling that my car should do that as it has memory seat/column. I'll have a play tomorrow :)
  4. keefysher
    2,681
    875
    May 4, 2007
    Hampshire
    Your Mercedes:
    Andy, here is the script from the manual:
    Screen Shot 2019-03-14 at 20.29.11.png Screen Shot 2019-03-14 at 20.29.36.png
    EmilysDad likes this.
  5. OP
    EmilysDad
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    These Germans are clever ..... ;-)
  6. grayb
    grayb Senior Member
    553
    65
    May 16, 2003
    Kent
    Your Mercedes:
    E350CDI (S212) 2010
    Not that clever - they only include the function if you have memory seats, which seems a tad mean.
  7. Capra
    Capra Senior Member
    2,154
    500
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    W204 2013 C350 CDI Pan roof
  8. keefysher
    2,681
    875
    May 4, 2007
    Hampshire
    Your Mercedes:
    The inserted screenshots came from my W166 manual. The first doesn't specifically say memory seats, why not give it a go? See what happens.
    I did see a video on a non memory seat where the guy said it works on other models:
    Capra likes this.
  9. Capra
    Capra Senior Member
    2,154
    500
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    Be right back.....
  10. OP
    EmilysDad
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    You still there? :D
    Capra likes this.
  11. Capra
    Capra Senior Member
    2,154
    500
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    Made it back :). It looks like this feature is only available with memory seats, did some Googling, and that appears to be the general consensus.
  12. grayb
    grayb Senior Member
    553
    65
    May 16, 2003
    Kent
    Your Mercedes:
    E350CDI (S212) 2010
    Exactly what I found with the W212...
    Capra likes this.
  13. keefysher
    2,681
    875
    May 4, 2007
    Hampshire
    Your Mercedes:
    but did you have a play with the actual car? not everything is on google :confused::cool:
  14. Capra
    Capra Senior Member
    2,154
    500
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    I did indeed. I then searched a few forums.
  15. Srdl
    Srdl Senior Member
    1,674
    707
    Oct 8, 2015
    Hampshire
    Your Mercedes:
    GLC43 AMG 2018 (X253) Premium Plus
    Yes, definitely only with memory seats. I presume this is because the system doesn’t know where to revert back to after dipping if it does not have a memory for the normal setting.
    Capra likes this.
  16. Capra
    Capra Senior Member
    2,154
    500
    Jan 27, 2018
    Gloucestershire
    Your Mercedes:
    Makes sense when you think about it.
  17. OP
    EmilysDad
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    Meanwhile ..... I had a play with the mirrors thus morning & my passenger mirror now dips when I select reverse :)
    gramey and Srdl like this.
  18. OP
    EmilysDad
    6,882
    977
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    R320 2007
    It still puzzles me as to why the interior mirror isn't included with the seat & door mirrors ..... my 1999 Omega's interior mirror was.
    Capra likes this.
  19. Blobcat
    Blobcat Moderator
    10,686
    1,261
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    My W213 would dip the passenger mirror (if I left the selector on pax side) and I didn’t have memory seats.
Share This Page
