door trim removal
i plan on sprucing the old girl up a bit in the next few weeks (its a 210 need i say more?) anyhow, while im at it, i plan giving it a nice helping of waxoyl wherever i can get it in! on the front door trims (although not on the rear ones) is an SRS badge which i can only assume means the front doors have side airbags in them. is there anything i need to be careful of or be aware of when removing the front trims as i dont really want the airbags going off when my face is a few inches away! its a pre facelift, if it makes a difference
Dosco
W211
When replacing the winder mechanism (both front doors) in my W210 I did not do anything special other than leave the keys out of the ignition and was very careful until I was able to disconnect the supply.
Maybe I did something not quite Kosher but nothing went off with a bang:cool:
Roger
If you have to disconnect an air bag,,do not turn on the ignition, or a fault will be stored,,,if you need any papers for dismantling just ask,,I have most already printed off
type49
The airbag is behind the panel & you will not need to disturb it.
Its funny how people see airbags!! the do,s and don'ts!
They are as safe as any other item on the car, just remember rule number 1 & 2.
Disconnect them with the key out, and lay them flat with the travel of the bag facing up, in other words, if it did deploy, it wouldn't shoot the metal part up first!!
And do not lay them down in the sun :D:D
Thats a old wife tale Malc, what temps do they reach sitting in the car with full sunlight on them!!:D
Better tell MB that then they can delete the warnings in WIS,,you never put them in the post either
I have never heard of a bag going off while being removed or stored!!
Have you???
They have to put the warnings "in case" of a faulty bag,
Do you want me to quote every reply now with the warnings and do,s and dont,s to every DIY job???:confused::confused:
Have you???
I refuse to answer that on the grounds that it may incriminate me :D:D
But no I have not since you ask,,one did blow up in the post though
if its not too much trouble Malcolm, the papers would be handy for this, just in case theres anything im unsure of when i get into the job, thanks
If I send you as little as possible you can come to the meet :D:D
Is it a saloon or estate and I take it it is around 1998-9
hehe! i plan on being there if its sorted! its a 1999 pre facelift saloon
I have sent a few,,no idea what they were though:D
cheers Malcolm. im sure i should be able to work something out from them!
