Double-Din question?
N
nismo915
Does any one know if a w210 E class double din head unit fit my w208 CLK please??:confused:
Do you mean physically or electrically please
N
nismo915
Both really, just wondered how much of a job it'd be?
A double DIN unit will go into a 208 a member here miffy has done a nice installation,, do you want to fit the comand from a 210
Alfie
Surrey/Cotswolds
www.comand.co.uk
Yes it will.
If its comand you are looking at then you should aim for one of the following part numbers assuming your w208 was built after august 1999;
A210 820 54 89
A210 820 56 89
A208 820 40 89
A208 820 44 89
If your CLK is a pre august 1999 build then you should look for an ML comand unit instead which is A163 820 36 89 or A163 820 14 89.
The CLK will require the two mounting plates for the comand which are not present in the W210.
