- Aug 25, 2006
- Location
- Midlands / Charente-Maritime
- '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi
That is an Indy.The sensors are around the £100-115 range depending on which one it is and then you will have at least an hours labour for fitting of that which will be again in the £100+ range for a dealer. So they are probably adding another hours labour for doing the regen.
Do you have a local independent, they would probably be in the £200 range for the whole job.
To be fair it sounds like a reasonable amount to get it properly sorted.
