I have a e250 cdi blue efficiency estate, built in 2011. Recently the engine management light came on and car went into limp mode, won't rev above about 1500rpm.
Went to local garage and they said exhaust pressure sensor was problem but after fitting new one the problem remains.
After an unsuccessful attempt to sort the problem by using an additive and trying to take car for a longer drive at adequate revs to burn off soot, the light stays on. The problem was that in limp mode it was difficult to get the car revving fast enough. It is an auto so I tried all 3 modes. Perhaps I did not follow the clearing protocol correctly.
So I have booked it into an indie specialist in Somerset next month.
Is it wise not to drive it until then?
Could it be another issue, I am not certain that the garage who did the initial work have the correct OBD equipment. I think STAR is the best one.
Any advice about attempting self clean of dpf, or other issues which could be causing this, I am grateful.
