DPF level.increases during Regen
Jules13
EClass 220cdi 2012 W212
Hi again.
Yet again the DPF is playing up.
It drives normally, no error codes stored, no EML and DPF filling at normal rate.
During a regeneration, the fill level goes down as usual, but suddenly stops and starts shooting back up to almost full, then goes down a bit before Regen stops as system thinks it's run for long enough. Done this twice now. I'm about to change the DPF sensor as it occasionally throws a fault code about perimeters being outside of range.
Any ideas?
Running an Autel Maxi AP200 app so that's how I see info.
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Hi again.
Any ideas?
Have you checked both pipes coming from pressure sensor for blockages. The fill level is determined by the pressure.
Jules13
Pipes clear, but I've changed the sensor now and it seems to have sorted the problem.
