Liam dean 123
New Registration
- Feb 22, 2020
- Vito 14 plate
Guys, first post on here so go easy! Basically I’ve tried 2 separate independent mechanics, merc Stockport and roanza (merc Trafford park) and still no one can fix my van and it’s doing my head in!!!
1)EML came on, independent garage said DPF blocked time get it cleaned, 2)company came out and said DPF Reading’s were fine, changed the sensor but van still thinks it’s blocked and must be faulty wiring so put old sensor back on
3)took it to merc Stockport who changed a section of wiring to the sensor and light went off, but came on a week later,
4) took to roanza who said it was the sensor, had it replaced and the EML light reset
5) light has come back on and says on dash to drive at high engine speed
I’ve done countless laps of the M60 not dropping under 2500 revs but I’ve just read that it won’t regen with the EML light on, the light was off for about 10 minutes but came back on as I was on my way to get on the motorway. Is this true or should I get some of the cleaner fluid and do another lap of the M60? Or book in with another mechanic for a forced regen?
I’m not trying to save money or cut corners I’m just sick of it been off the road and paying different people including merc who can’t fix it!!
many advice welcome and thank you in advance!!
