DPF
Concho
Steyning
2007 CLK 220D Sport
How do know if my car has a DPF?
CLKW209 220D (2007)
whitenemesis
CLS55 AMG '05
Datacard is the build record for the car. Lists what was on the car when it left the production line and any additions officially added afterwards.
Post your VIN in the VIN Decoder thread and some one will generate the datacard for you. It may be attached to your service book anyway..
Concho
Concho
Steyning
2007 CLK 220D Sport
There is a yellow folder and inside there are a lot of specifications all in German on white paper, is that it.
mikestrivens
Stockport
if it has lots of numbers on then yes.
whitenemesis
CLS55 AMG '05
The numbers are the same in either language!! ;)
Look for SA 474
Concho
Concho
Steyning
2007 CLK 220D Sport
I cant see that it says SA 474 anywhere. There is a bit that says "Partikel: 0,021 g/km but that's it.
whitenemesis
CLS55 AMG '05
I don't think you are looking at the datacard..
If you don't like to post up your VIN in the Decoder thread you can pm me and I'll check for you.
Concho
Concho
Steyning
2007 CLK 220D Sport
Just phoned up Mercedes and the thing I was looking at wad the EU spec thing. Cant find a data card anywhere! Anyway, he has confirmed that it does not have a DPF!
S.Speed
Lancashire
Older Citroen Now :-(
Nonchalantly wipe your finger in the exhaust..
Is your finger clean ish?
yes = DPF fitted
No = DPF not fitted in which case well done .. You are lucky.
Concho
Concho
Steyning
2007 CLK 220D Sport
yes = DPF fitted
Why is having a DPF a bad thing? do they do wrong a lot then?
c15htn
Milton Keynes
'00 A208 CLK320 Convertible.
There's not a lot too go wrong, they work....... or block up and fail. When they do that they cost a fortune to replace.
