draining fuel tank clk 270 cdi
alf1956
alf.marshall1956@gmail.com
clk270 cdi diesel
Hello
which is the easiest way to drain the fuel tank ? I was going to take out the sender unit & put a pipe into the tank connected to a pump as I am guessing there wont be a drain plug due to possible theft.
If you’ve AA cover, accidentally drop some of the wrong fuel in, and they’ll send a specialist to you to drain your tank included in your cover :cool:
Hello
As good a way as any.
Steve@Avantgarde
Bristol/Somerset
T
Hello
This is the only way as yours will have a lift pump and not an electric pump. If it had an electric fuel pump I would have suggested disconnecting the fuel supply pipe and bridging the fuse for the pump and using that to drain the tank
Westheath
South London
Or pull the fuel filter feed pipe off and use your electric pump to drain off.
www.ckinsurance.co.uk
