Drips water through roof
consort
East Malling Kent
Punto Grand Evo Esssee, ML300, TVR 4.5 Cerbera
On the drivers side on my R230 I have a water leak between the roof and windscreen A pillar seals.
Is there an adjustment to tighten the roof up?
Had a wet leg yesterday!
Yes and I have the details :D
OK you can edit out your address,,,, please not that if you treat all your rubber deals with gummy pledge or a good silicon grease the roof will close tighter
kerwin6265
Liverpool
CLK320 convertible
Leaking roof clk
Hi Malcolm,
Have the same problem on drivers side leaking where the pillar meets the roof. Could you supply the same info please?
adrgraphics
Leighton Buzzard, Beds. UK
CLK320 (A209) Cab 2005
Hi Malcom,
Not sure if you saw my other post on this yesterday but yes, if you could supply these details too that would be great. :)
Hi Malcom,
acom
The only thing I have for a 209 is the replacing the seal over the door window and I have sent that to you.
The other seals require some lubrication with a silicon oil like Gumi pledge
Hi Malcolm,
208 or 209 please
C
consort
East Malling Kent
Many thanks again!
Brotherjenks
Surrey
SL500/R230/2002(52) / W114 250C
Is there a standard fix for a small ( and by this I mean tiny ) gap appearing on passenger side seal between front of roof and the A-pillar? Can an adjustment be made to realign the roof?
Clkrichard
Chichester
CLK 320 Cabriolet 2004, R 230 SL 500 2005, new A class AMG Sport.
Malc please can you ping me the R230 roof adjustment too ? I plan to Gummi Pflege the seals this weekend too but adjusting might be needed. ( I wont do the back before coming to see you ! )
Richardfhall@gmail.com
Clkrichard
Chichester
Malcolm are you back on here now ?
Everything ok ?
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
He seems to be posting on the W124 forum... Can't recall its URL but someone posted it up .. I assume something was said here for him not to be around...
