Drivers Seat back stuck in the horizontal position
alanuk400
Belfast NI
www.vipsec.co.uk
2018 W222 Mercedes S-Class LWB & 2006 R171 SLK 55AMG
Hi
My 03 W220 Drivers seat has stuck in the horizontal position, I put it back to clean it and thought it went back further than it should, now it only lifts up about an inch and then stops.
So the motor is ok, there is nothing caught in the gears,they turn about three full revolutions, when it stops you can hear the relay clicking.
It's as if it thinks it is in the upright position.
Alan
I have a feeling that you will have to take it out, dismantle it and put it back together in the upright position.
I can provide you with some papers
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
I left it up to my indie today and he put it on star, it didn't come up with any fault, he said it might be a sensor thinking it is upright, he is going to do what you have suggested.
Is there a reset procedure to try, ie 5 seconds at the end of each travel.
Alan
The seat has gone past the sensor, and is operating in the wrong sensor mode, by removing a sensor then running the motor to get the back upright should cure it
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
Thanks, I am just off to see him, I will let you know.
Alan
coolpot
c180/2002/1.8p
:Oops: ive heard this happens occasionally after windows have steamed up for some reason :)
Yes the condensation drops onto the sensor, common fault when you are young:cool:
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
Hi Malcom
Could you email me some papers, the garage hasn't started on it yet.:mad:
Alan
I have sent the papers, found the E mail from your web site.
I have no details on what form the sensors or stops take, if a sensor blanking it off would work. The seat knows where it is in the memory as it counts the turns on the driving motor.
The end or limit switch must have failed or be bent
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
Thanks Malcolm
What I am going to try tomorrow is to loosen the cogs so we can lift the seat back up, do you have the paper for the back of the seat so I can see where the bolts for motor are.
I can't blame the indie, he didn't want to spent hours on it just on speck.
Alan
What year is the car please up to 31-08-02 or after
OK its 03 need Email address again please
OK Alan and I will send it now
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
I have just spent all day stripping the seat, got the seat back up, now having difficulty putting it all back together
Nothing that I can do to help there :(
3rab9
hi there ,i had a simular problem on my clk 320, my problem was that some of the motors were working but others were just clicking , after a little head banging i traced the fault to the fuse in the boot, there are on my car three fuse boxes and several different fuses for the seat, just check them all it should tell you on the fuse cover which fuses are which !!
hpoe this helps
mark..
alanuk400
alanuk400
Belfast NI
www.vipsec.co.uk
  • #19
Hi
I checked the fuses before stripping, after stripping, the motor was working ok, just looks like something was stuck in the teeth.
Had to move the car with the seat out, guess what, SRS light came on:Oops:
Not my day at all.
Alan
www.ckinsurance.co.uk
