HERBIEMERCMAN
- Dec 15, 2008
- Location
- PRESTON, LANCS.
- 97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
Hello everybody, Not sure how many members have been involved with the w210 heater / climate control. I have repaired my 22 year old duo valve several times but now it is time to replace it, it is 'letting by' when the valve is supposed to be closed,and on hot days your getting heat you do not want.
Anyway, i have obtained a valve from 'Three Pointed Parts' it has been tested and cost one third of the OEM price for a new one.
My question is how to remove the valve, it is mounted on a sort of rubber bushes with conical tops, and the two engine water pipes on the underside of the valve there are two straight water connection nozzles which must push into the plastic elbows which terminate the engine water supply pipes, there must be some kind of 'O' ring inside the elbows to make a seal?
So does anyone know how to disconnect the rubber bushes which support the valve assembly and how to disconect the pipes on the underside. see pics. Herbie. nnect the underside water connections ? Any advice will be appreciated. Herbie.
