Duo valve test?
mercmadjim
Cornwall
SLK230k
Is there any way to test the duo valve? I have voltage going to it, but using a multi meter, can I test the valve itself?
Number_Cruncher
1995 W124 E300D TE
Measure the resistance between the centre terminal and each outer terminal, and report back.
The reading should be read on the 1k range, its unusual to have both coils O/C unless say the passenger one failed some time ago and you did not notice.
You can remove the top and see if there is a broken wire from the coils, though they often break on the inner part of the coil, a break on the outer turns is easy to repair, but not the inner
http://forums.mercedesclub.org.uk/showthread.php?t=25909
basamir
Barcelona
W202 from 07/1997
I did that and got nothing..zip, nada, etc, is it broken?:(
If no resistance are between pins that means that your solenoid are broken.
You can repair them all that you need is to repect the topic linked in malcolm's reply.
I have me too problems with my duo valve but they aren't broken because the resistance between pins are the same 0.20 Ohms
mercmadjim
mercmadjim
Cornwall
SLK230k
Thank you Malcolm, any idea how much they cost? my old W124 has a good one, the pipe work is slightly different, on the SLK all 3 pipes come out on 1 side, and on the W124 there is 2 on one side and 1 on the other.
But if they are reasonably priced I will buy one.
Thank you Basamir, there is no thank you button on your post??
basamir
Barcelona
W202 from 07/1997
I think that a new duo valve is about 100 Euros.
Slowtack
Had duo valve problem last year on my W124 estate.
No heat either side, solenoids ok.
My canny mechanic guru fixed it by taking out the internal rubber grommets which were swollen on one side and replacing them the oposite way around.
Yes and a good fix :D
fullmeister
Northumberland
w124 250D estate
Are the internal seals availible for rebuiling purposes ? I took mine apart to clean it and now it leaks like buggery
They were not made to be repaired,,it is possible to make your own gaskets, and O rings can be bought in any size.
Cleanliness of the joint faces is very important. I will try and dig up a link that covers this if I can find it
fullmeister
Northumberland
w124 250D estate
Cheers lads but I decided to get a scrapyard one (12 quid) , when I removed the top covers the windings were like a birds nest !
Top link though.........
