Dynamic Select Toggle Switch Position
LGS205
C Class S205 220d 2016
Not sure how possible this would be, assume it could be time consuming, but does anyone know if it is possible to swap the dynamic select switch with the volume control on the centre console? For left hand drive, the dynamic select is conveniently positioned, however, for me in a right hand drive car, the switch is just a little too far away, not as easy to access and use as it could be. It would make more sense for it to be on the drives side, especially as it is possible to control the volume from the steering wheel.
The volume and dynamic select switches and their setting within the control unit look to be the same size and shape, so wondering if it is a case of removing the switch and surround from the console and then moving them to the preferred side and refit. Is this something that is possible/has anyone done it?
