Hope someone can make some suggestions. The clutch fails to return to the normal position after driving for a while and it's getting worse If the clutch pedal is pumped it does return. Problem seems worse when the engine is warm. The local garage can't seem to identify the problem. Was told it might be a problem with either the slave cylinder, master cylinder or worse case the main input shaft?????????????????? I would appreciate you advice
