e 320 cdi heating
undeckedhomer
Banned
blackpool
e 320 cdi aventguard with amg spec
can anyone help i have a e320 cdi the heating in the cabin is not very good iar is not very hot and when air is on fastest setting not a lot of air comes out of the vents i have the charcole pollen filters on this car plus the temp on the dash show 60 i am going to get a new thermostat dam 5 day wait from germany wots that all about ??? and 35 quid for a thermastat ???
jberks
I presume you are saying you've replaced the filters?
How old is the car?
£35 for a stat - bargain - Jeep wanted £120 for one on my Cherokee. (Flogged it and bought a Landrover).
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
its a 2000 w reg all filters chage fuel air pollen but still litle heat comeing nto the car its the warmest on screen demist ju no air preasre through the vents
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
would it be a good idea to change sencer at the same time then
jberks
Does the fan speed up on the fastest setting? Does it noisier?
Assuming the fan does speed up, it sounds like the vent flaps are sticking. Try removing the fliter and see what the air volume is like at that point. We need to ascertain whether the fan is at fault or the directing of the airflow.
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
fan speed ok can hear the vents moveing butno heat flow but the temp gauge is not reading high about 60 would this be the fault
mercedes13156
West Lothian
CLK 200 Cabrio and a Ford Kuga
Common problem
Get the pollen filter out. You'll probably find that it's absolutely jammed with all kinds of muck. Put the cover back on and it should work perfectly. I had that problem with my car 50,000 miles ago. I keep forgetting to buy a new filter. The heater is great.
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
ok got new pollen filters on order so how about the engine temp 60deg ??
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
ok changed the charcole plollen filtes x2 checked the fan with my hand in where the filters go loads of preasure but not that much diffrence with the ew filters theres a lot more with the new ones but still not much heat though its not red hot just warm
panason1c
Somerset, UK
Fitting a new thermostat will cure your heater problem, 60 degrees is too cool.
undeckedhomer
undeckedhomer
Banned
blackpool
  • Banned
is there a way of bleading the system after refit of the thermostat then got on on order from the stealership
