PJC238
New Registration
- Sep 25, 2023
- E Class Coupe 220d (C238)
Hi all,
I need some advice.
A couple of weeks ago I cracked the passenger headlight lens on my e class. I put some clear film over it a temporary measure until I could get the lens fixed. Unfortunately, after the heavy down pour last week, water/moisture got into the headlight and now the beams are not working. The LED strips works fine. tI get are Adaptive Light System inoperative and Dip Beam Fault.
I have accepted the fact the headlight unit needs replacing, but I understand there are two control modules that are attached to the light as well. Do I need to replace both of them? and if so, where can I locate the part numbers?
To make matters worse, the good RHS headlight has completely stopped working as well and I have fault warnings for both Blind Spot Warning and Speed Sign recognition. Is it likely the initial fault with the water damaged light has caused further issues with the cars electronics? may be a fuse has blown?
I need some advice.
