R
rjsdavis
Hi all - I've been spending some considerable time trying to resolve a heater control problem - with no luck. I have just replaced the duovalve, and this has made no difference!
I have spent more time testing the system, and have discovered that when the car is driven from cold, and the heater fan is set to "0", only ambient air comes into the cabin, which gets progressively warmer as the engine does. If I leave the vents open - nothing particularly comes into the cabin for the first 35 mins.
After 35-40 mins, things get worse. I have the EC button switched on, as currently I have no refrigerant in the a/c system, so there's no point in running the air-con system. I am simply trying to fix the heater problem at the moment. After 35-40 mins, the heater fan starts to operate, and blows HOT air into the cabin. If I leave the vents closed, I can soon start to feel the centre console getting warmer and warmer, as the hot air is simply circulating around inside the centre console of the car.
If I open the vents to let the air in the car, I can feel that the volume of air is the equivalent to the heater fan being set to about 1.5 or 2.0 on the main control panel. Also - the EC button red light comes on, which indicates that the fan is operating. The EC red light does not come on for the first 35 mins or so, so I can deduce that for some reason - the heating system appears to want to turn itself on. This happens every day, and after about the same amount of time each time!
The temperature of the air is the same (hot) irrespective of whether the temp controls are fully red or fully blue.
Therefore, I am not sure what to do next. I have tried pulling off the duovalve cable as you suggested, and it made no difference at all. This thing is really frustrating me!
