E CLASS ESTATE BOOT LOCK PROBLEM
Status
Not open for further replies.
AHJ
West Sussex
HI
I HAVE A FRIEND WITH A W210 ESTATE? THE ONE AFTER THE W124
HE HAS A PROBLEM WITH THE BOOT, IE CAN NOT OPEN IT?
WHEN THE LEVER IS PULLED TO OPEN YOU CAN HEAR THE MOTOR/SOLENOID WORKING AND THE BOOT LIFTS ABT AN 1" THAT LOCKS BACK DOWN AGAIN
ANY IDEAS GRATEFULLY RECD.
Bob 2316
London UK
is he able to clamber over the back seats and remove the interior panel of the tailgate so that he can see what might be happening when the relaease is operated.??? just a thought!
best regards
bob
dave elcome
Maidstone kent
I would suggest pulling the fuse for the central locking, that way the tailgate lock will then work manually, this will alow the tailgate lock to be inspected.
I would imagine that the locking motor micro swith is either defective, or needs adjustment, they can be obtained separately if needed.
The usual reason for these going wrong is the tailgate being slammed onto the striker plate.
Hope this helps.[/quote]
A
AHJ
West Sussex
many thks to you both
like the idea abt the fuse, however none of the keys fit/work the boot lock (it has alway been like that!)
interior panel of the tailgate seems the only way.
thanks
fuzzer
Scotland
W202
the boot lock will just be stiff through non use.
Open the boot , keep it at eye level and use WD40 to loosten the lock skoosh , wait a min and then try the key....
The boot sounds like its independently locked for some reason , either that of the boot lock has been changed.
ITs worth a try , most people just use the alarm fob and never even think of using the key
The bootlock on my car did not even let the key in when i bought it.. ITs as sweet as a bonbon now :D
Status
