E Class W211 Wing Mirror Indicator Glass Replacement
R
RICHARD COOK
Can somebody post me a link to a guide on how to change the glass indicator in my drivers wing mirror as mine is smashed :(.
It's an E class W211 by the way ;)
Thanks in Advance
Just fold the mirror, and on the end you will see a square hule on the outer edge center. depress the catch in the hole by pressing with a suitable object, and the cover slides off
You remove the glass by pressing in at bottom, unhook spring along top and lift glass out
R
RICHARD COOK
Folded the mirror (it's elecrtric btw) and there's no hole :shock:
Any ideas or photos?
If you pop up your email address for a few mins, you can go back and delete it when I say , I will send you the paper on how to do it.
R
RICHARD COOK
Many thanks for this!! :D :D :D
Paper sent :) go back to your post and by using "edit" you can remove the address,, you only have an hour to do this.
Welcome to the forum
R
RICHARD COOK
Thanks, i'm not sure mine looks like this, I'll post up a photo of my mirror folded.
R
RICHARD COOK
Left my camera at home :(. My mirror swivels on the mount and has a sealed end with no holes. My E class is a 2008 model. Any ideas?
I am so sorry richard,,I cant help with a 2008 car, maybe SAM can
R
RICHARD COOK
No, the end is body coloured and is part of the actual mirror. The whole mirror swivels in rather than folding.
Cole@MBS
www.mbssouthampton.co.uk
Remove the glass, then round the inside of the frame there a few torx 20s, remove these and then wiggle the case of, looks a real crap job!
Then to me this looks as thought the glass has to be removed and it has a screwed together case, like we had on the 129 etc
Cole@MBS
Will print it off and post in a mo Malc, some great e,mail exchanges this morning young man!!
R
RICHARD COOK
  • #20
I assume the process for removing the lense is still the same? Press the bottom of the mirror and unclip the top?
