E class
Discussion in 'General Mercedes-Benz Related Discussion' started by Stevie77, Nov 23, 2012.
  1. Stevie77
    Stevie77 Member
    18
    Aug 10, 2012
    Bristol
    Your Mercedes:
    Clk 220cdi
    Hi guys, just wanted some feedback please. Thinking of buying a 2003 e class 270 diesel. Has done 100k with fsh, not sure if it's Mercedes tho. Looks really clean and high spec. :neutral::neutral::neutral:
  2. st4
    st4 Banned
    8,624
    Apr 6, 2008
    Sunny Scotland
    Your Mercedes:
    Disqualified driver
    Great car but research the valeo radiator issue.
  3. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
    That will be the only gripe to look out for really but should be sorted by now.
    Make sure it has a FSH too.
  4. OP
    Stevie77
    Stevie77 Member
    18
    Aug 10, 2012
    Bristol
    Your Mercedes:
    Clk 220cdi
    Yeah, that's what I thought it would have been done or gone by now!!! Was it not done as a call back then ? Also what does it cost to get it replaced ? Is it hit and miss if they go or is it just a matter of time !!
    Thanks for the replies anyway
  5. mersum1es
    mersum1es Senior Member
    1,959
    229
    Sep 25, 2010
    Finland
    Your Mercedes:
    No call backs. Very expensive, if auto transmission is badly contaminated and ignored too long. Like said , usually already blown and repaired. If not, new radiator costs under 200€. Overall, pay attention how automatic transmission is working, should be smooth and firm.
    SBC brakes is another big issue, if unit already changed, should have plenty of miles ahead. Otherwise prepare up to 2k costs, if cannot refurbished by software.
    Low mileage, try to find out is it true? (basically rather easy to cheat, diagnose software will show if done poorly).
  6. Spannaz
    Spannaz Active Senior Members
    791
    Jul 11, 2011
    Medway Towns, Kent
    Your Mercedes:
    Kia Sedona 08
    i have an E all beit a 320 diesel. Purchased it used with 92k and FSH, but i got a warranty a boy i am glad i did.
    I had the drivers door lock packup - locks bounce due to broken spring, new units have a modified part fitted to them.
    Duo valve failed - had cold air from front vents, hot air from rear. Kindly replaced by Cole @MBS while on holiday!
    Leaking Valeo rad -yes even at just under 100k it had not been replaced, but was done along with new torque convertor by Steve @ Avantgarde cost of around £1500!
    Cooling fans packed up, ouch at £815 for just the unit
    Soft closer on tailgate failed to shut boot - £300
    as you can see in the first 6 months we had a rough time, but all were covered by a warranty. Yes we got REALLY fed up with it, but now (touch wood) we have nothing but good times. For the money of these cars you do get so much comfort and i'd be hard pushed to want to give it up, as i'd really have no idea what to replace it with!
  7. MSG2004
    MSG2004 Senior Member
    485
    Jan 1, 2005
    Kent
    Your Mercedes:
    MB C Class 180k Se Auto Avtg Saloon.
    I have my eye on the old E class, this has made my mind up - no!
    In my family, we have 2 E class car bout on the 60 plate, both going strong, so may get the newer one in a few years.
  8. wheelie
    wheelie Senior Member
    475
    Aug 8, 2011
    Your Mercedes:
    W211 E280 Sport
    The w211 model from 2006 onwards Steve had over 2000 improvements to its predecessor so is probably the one to look at as a used purchase. "Touch Wood" mine is still going strong after 17 months and 30,000 miles.
Share This Page
