E200 - 4000rpm cutout
TaqMan
Huntingdon
Hi Guys,
Update to my earlier thread re: ABS light on, erratic cold idle and 4000 rpm cut out on my E200 94reg. (16v)
Replaced the OVP and cured two out of three!
Still got the 4000rpm rev limiter.
Any suggestions - it does it in all gears and all conditions - 4000 rpm and blerrrrgh it starts missfiring.
any suggestions please
Cheers
marnix
Looks like the car is in safe mode.
Could be just needs to clear the fault code or it could be the Lambda sensor for the emissions that is causing this
T
TaqMan
Huntingdon
Ta,
The Lamda sensor has a distinct chance of being a bit iffy.
can it be tested? ie buypasses or something to see if condition improves or gets worse
Cheers
Your fuel pump relay contains the engine speed limiter, is it the right one for the car, had a 126 with wrong relay, if you have relay 003 545 17 05 that cuts at 4k
Malcolm
T
TaqMan
Huntingdon
Hi Television,
Thanks again for helping!
Where is the relay - behind the battery? There isn't much back there, as I recall, a green coloured relay thingy next to the OVP and the ecu.
What would cause the limiter to suddenly cut in as the car would happily rev to 6000 before
TaqMan said:
Hi Television,
I think it is up front with fuse box somewhere, can check, these units have an Eprom that has the speed limiter info, if this device loses it memory then maybe they de fault at 4k. the one I have here cuts at 4k, its always puzled me as I cant think what engine cuts at that speed, only deisel maybe.if yours is the same number could be interesting.
Have a word with Luisoliver Regarding Relay in this section
malcolm
jberks
The rev limiter cuts in at 4k in neutral. Don't know enough about how it works but perhaps there is a sensor fault and it doesn't know you're in gear?
Just a thought.
Just a thought.
Though a replacement cured the 126, these units must have dual info, I will look up the spec of the PIC Eprom during the day.
thank JB, Malcolm
T
TaqMan
Huntingdon
You guys are all stars!
Thnaks for the help.
Jberks - its a (say it very quietly) manual
and the cut out happens in all gears and neutral.
Thanks again
Taq
Thanks again
Taq
It could be that the Pic serries Eprom loses part of its memory,or is it a switch somewhere that operates when the car moving, cant work that piece out yet as to where it could be on a :cool: 8manual.
malcolm
T
TaqMan
Huntingdon
More Info
Ok I've been on a relay hunt.
I found 3 behind the fuses
A small white jobbie in position A
A medium black one 201 821 0047 - winker relay I think.
And a Huge one 126 542 0332
are any of these the prime candidate for the fuel pump relay?
The fuel pump relay replacement at euro car parts is £12 + vat which seems way to cheap for one of the biggies
The OVP was £45ish
Cheers for any info
Taq
T
TaqMan
Huntingdon
Update
Hi All,
Just an update. - I replaced the OVP as per the earlier thread, This cured 2 of three probs - ABS and erratic idle but not the 400rpm cutout.
But after hunting for relays, disconnecting and reconnecting various black plastic boxes the 4000rpm cutout seems to have cured itself.
So thanks to all for your imput - my merc's happy again!
Cheers
Taq
Stevie A
Scotland
It must have been in limp home mode maybe due to the OVP being faulty in the first place and you've managed to reset it.
