Dean Pesticcio
- Nov 22, 2008
Hi, I have an M reg E200 estate automatic gearbox (124 'facelift')
I am having trouble with tickover idling, it revs at 2000 out of gear, when it is put into gear (gear box not happy) it jumps from 1000 to 100 a few times and eventually stalls. It runs fine when its cold! I am a novice desperatley trying to get my family back on the road. It has been looked at by 3 local garages that could not solve the problem. In the process I have changed the airflow sencor, the sencor next to the temp sender, adjusted the screw behind the plastic cover 100 times, tried 2 other second hand throttle bodies (on the first there was a 90 percent improvment for a month, when I changed the second its the same) I have changed the OVP relay for a second hand one and it runs the same, even without the OVP relay. I have checked all the vacuum pipes.
The local Mercedes dealer recomeded a new throttle body and ecu & ovp relay which comes to over a grand and no guarentee it wil resolve it. The bodywork and under body is all clean, itll be a shame to turn it into a chicken coop!
ps, this is my first time using a forum.
Any advice apreciated.
-Dean.
-Dean.
