E210 (E320) Elegance Estate - European Dipped Headlights?
G
ginetta
I've just bought a 2001(Y) E320 Elegance Estate and need to drive regularly to France.
I can't find any reference to switching over Euro dipped beam and back (as on my old Scorpio Ultima).
Is there something I've missed? Is there an easy bulb swap, or do I need to use the 'sticky tape'?
Regards
Alan
If you have xenons they can be switched, lamps with normal bulbs cannot be so it is back to the tape
LYNALL
Kent
My 2001 has xenons and have read a few posts ref the switching the magical lever, i have never found the lever or seen any pics of it anywhere but would love to know once and for all.
I have had the bulb out and felt all around the inside of the lamp had a look with a mirror etc etc but no luck.
Lynall
Let me have your Email address and I will send you the file
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I thought the "magical lever" was only on Bi-xenon headlamps.
Models 203, 209, 211, 215, 220, 230 with
code 614 Bi-xenon headlamp unit
Models 209 with code 615 Bi-xenon
headlamp unit with integrated curve
illumination
Models 230 with code 612 Xenon
headlamp unit
Models 211, 220 with headlamps with
projection system (halogen headlamps) can all be switched
