Do you only have the fault in R, you say there is a jolt, but does it then reverse OK. Is D OK.e220merc said:Does anyone know whats wrong when I put the gear lever into reverse the car does'nt move but when I press the accelerator it jerks and goes back.
Sometimes a failing MAF can give these symptoms, might be worth some diags to be sure.
jib
Dear All
I wonder if anybody knows what is wrong with the same problem that I have experienced in my newly bought 1996 W210 E230 Auto Saloon with a 101k mileage.
I have checked the gear oil level and it seems fine. The colour of the gear oil is looks clear (not brownish).
Relating to gear, propeller shaft, engine mount or something else? Please advise, and, if possible, how to fix it on a DIY basis.
Regards
Sean Ng
Dear All
I have sorted the issue out!
After I change the differential fluid, the problem is gone. My car has no more jerking and vibration when it reverses. It is now smooth.
The old differential fluid was so dark and sticky. When I measured its capacity, I was surprised that it was about 1.8 litre, which is not correct. The capacity for a 1996 W210 E230 differential should be around 1.1 litre. I suspect that area of maintenance had been overlooked, or ignored, for years.
Anyway, the concluded causes of my issue are:
(1) Worn engine mounts; and
(2) More importantly, sticky and overfilled differential fluid.
I feel I am lucky as my problem does not relate to transmission or engine.
I must thank those who have given me their comments and suggestions.
I hope this will leave a reference for those who may have the same problem as mine.
Regards
Sean Ng
Dont get that diff capacity bit at all ??????????
but how would somebody be able to keep filling it up at the same time it would be pouring out the filler hole ?
