e220 1994 no power to fuel pump and no spark to plugs
male220
hi there
i went to start my 1994 merc e220 petrol and she wont start. checked all fuses and relays and all fine. there seems to be no power going to fuel pump and no spark from plugs. :confused: i tested the fuel pump with external power and shes working fine. has anybody got any ideas
cheers
mal
Alex Crow
Super Suffolk
do you have an immobiliser fitted? do you have remote locking and a silver sticker stuck in the windows declaring mecedes approved alarm system fitted, or some such guff? i presume it is cranking over ok. possible immobiliser fault or ovp relay.
M
male220
theres no remote central locking on the car.
cheers mate
jibcl500
Cambridgeshire
CL500,ML55,SLK280
OVP relay, its next to the battery the one with the fuse on the top, pull the OVP out with the battery connected and plug it back in again, the car should then start.
jib
M
male220
took out all relays and pluged them back in still no joy. check condition of all relays the kickdown relay 0035455005 is looking a bit uspect. is this the fuel pump relay aswel?
Yes the kick down can also be the fuel pump cut off as it is called it could be 0015429619 they can get dry soldered on the relays,,once again take it out and bridge pins 7 & 8
