E220 (2001) Audio 10 CD player wont turn on
nic673
I recently noticed that the cdplayer/radio wont turn on, it could be connected to the battery going flat recently but im not sure. The CD display wont turn on and the display on the dash jut shows "Audio ---" does any one know how to fix it please?
BlackC55
South coast
C43
Make sure you have the code.
Remove the radio and remove the power connector and then reconnect it. Put the code in then it should work.
often----- is asking for a code, most cars of this year are code once from new
N
nic673
taking out hte fuse worked perfectly, thank you
