e220 air mass sensor
marc124
I took my e220 est to a specialist. They said my ams is faulty and must renew. Using diagnostics they said i should replace this then diagnose gin to se if anything else is at fault.
ams - £399 + vat from Mercedes.
can get it for £195 genuine part, but a patent is £68. Not sure what to buy.
Anyone out there know about AMS, changed one? Go chep and see what happens or by t:confusedhe bosch one.
Had a look at the existing unit. Has no brand names on it so may think it i a patent replacement anyway.
any help / advice would be grateful
thanks
Marc
jibcl500
Cambridgeshire
CL500,ML55,SLK280
None genuine replacement fitted at the moment could be the proble, £65 none gen part is cr@p and shouldnt be fitted, go to MB and ask the price and part number also enquire if its a Bosch unit if so find a local Bosch agent and buy through them as it will be less than MB by about £100.
NEVER BUY A NONE GENUINE AMS OR MAF!!!!
jib
Parrot of Doom
Manchester
Mercedes will be trying to sell you the MAF and the bit of pipe it comes in. You only need the insert, which is normally held with 2 torx screws. So theres a saving for you.
As above, find a Bosch outlet and buy from there at a fraction of the price you've been quoted.
jberks
Genuine MB or Bosch only. There are some cheaper options out there but they rarely work properly. I was under the impression that the one I put on My 240 was towards the top end price wise and that sice then the prices have come down a bit anyway. Mine was around £250 so your quote of £400 surprised me. Fitting is a 2 min job for a hamfisted amateur so labour should be minimal.
M
marc124
thanks Guys
I will get the part number and have a look aorund.
cheers
kth286
E320 Coupe 95
marc124
Very happy to help you if you are anywhere near Reading/Berkshire area.
www.ckinsurance.co.uk
