Charlie2007
- Nov 7, 2007
hello i am new to this forum, I own a 1999 e220 cdi avantgarde auto.
I have an issue regarding the idling on this vehicle.
Whenever you press the brake pedal, whether it is in Park,Reverse,Neutral or Drive the engine speed drops and hunts up and down. As soon as you lift off of the brake pedal the engine speed returns to normal.
Now the vehicle has been to an auto electrical centre and I have been told there are no faults logged within the diagnostics. Another feature is that when you disconnect the multifunction brake light switch, and bridge two of the wires together the fault is no longer present, however the ESP,BAS and ABS warning lights come on. i therefore believe the fault may be electrical. If anyone can offer me any technical advice on curing the fault I would be most grateful.
