E220 cutting out
Stephen Archer
W124 E220 Auto 1995
Afternoon everyone.
I have a 1995 E220 Auto with an intermittant problem.
Driving along happily, and the engine cuts out. Dashboard lights all on, engine cranks fine but won't catch.
Leave it for 30 minutes, engine starts and runs fine for a few months.
Been told to check the 'fuel pump relay'.
Have Googled and there seem to be various locations (and part numbers?) specified for the relay, behind the battery, in the box behind the fuses?
I have a green relay in behind the fusebox, 001 542 96 19, with a 30amp fuse in it. Is that the Fuel pump relay?
If it is, I've been told to 'bridge' it next time it happens to confirm the diagnosis.
I've no idea how to do that?
Any assistance gratefully received.
Thank you
Steve
Johannesburg, South Africa
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K 2019 E63s
Sounds like the symptoms of a crankshaft position sensor fault.
Cuts out, won't start, then restarts when the engine has cooled down.
Stephen Archer
W124 E220 Auto 1995
Thank you for your reply.
Stephen Archer
W124 E220 Auto 1995
I don't believe it is a heat issue as the first time it happened the car had been running for less than a minute. I will add that to my list of things to check though.
docmercquad
E320 1995/280TE 1994 /1984 230CE/ 2001 320 AMG
It has got to be either the crankshaft sensor or the OVP (over voltage protection) relay under the cover behind the battery. Usually to the right with its own metal clamp if you are looking straight at it. Has a fuse on top. Try part number 000 540 67 45. About £70 from Mercedes. If you want to bridge a relay join pins 30 and 87. This applies to a standard 4 pin relay like the green fuel pump relay. Dont try this with the OVP relay. The crankshaft sensor is not difficult to replace. I would do it anyway on a car of that vintage. They are known to fail usually at the most inconvenient time.
mioba
Nottingham
If its the OVP, you cn disconnect it, wait afew mins and then reconnect it.
Check all vac lines, W124 is a vac driven beast
