E220 Diff clunk
Fettler
Cumbria
E220/99/2151
Hi all just purchased a 99 E220 cdi auto If i back off the accelerator and then accelerate a clunk is heard from the rear (diff?) Im guessing its wear in the diff or drivetrain?
Any suggestions how to pin point the issue?
Cheers
star
Reading
Smart + others :)
Look closely at the front rear subframe mounts, they are more likely to cause a thump when on/off accelerator. The rear diff mounts rarely go but we have change a few.
F
Fettler
Cumbria
E220/99/2151
Thanks for that I will be checking that later :lol:
Frontstep
T210 320cdi
My estate needed rear subframe mounts for a clunk on take off.
brianbrian
cockney in the West Country
w124 250D, SL129-deisel
Get the car over a pit and let some one put it in d and r a few times, while some one looks for movement under the car. Hope this helps
F
Fettler
Cumbria
E220/99/2151
Thanks for the great advice, checked out the sub frame bushes yesterday the fronts are well shot.:rolleyes:
Think I will replace the rears at the same time.:)
Can anyone advise if these can be changed by me or is there specialist equipment required? (bushes pressed in?):confused:
Pathfinder
Gourock
Cannot imagine it would be easy to change these without the car up on a lift?
brandwooddixon
Wolverhampton
S63 Coupe 2014
Certainly they can be replaced as a DIY job.
I only replaced the front ones on my old W210 with my car on the drive - I wrote a DIY thread detailing it.
They are certainly a pain to remove - don't be tempted to burn them out, there is too much rubber to do so without setting fire to your car.
You'll need a number of axle stands as well as a trolley jack.
Check the thread.
Pathfinder
Gourock
Rear subframe bushes - I thought the diff had to be dropped in order to drop the subframe?
brandwooddixon
Wolverhampton
S63 Coupe 2014
Generally the rear ones don't wear that much.
In any case they should be replaceable but are removed from the bottom of the sub-frame, rather than the top as the fronts are. This would mean that you would need something under the car in order to help press them in, rather than pressing then between the sub-frame and the chassis.
Leverage may be a problem when lying on your back, but it should be possible.
Oh, and it's best to work with one side at a time and only loosen the bolt for the rear bush as realigning the sub-frame afterwards could be difficult for a DIYer.
F
Fettler
Cumbria
E220/99/2151
Check the thread.
Cheers for that just read your write up. Will give it a bash, pardon the pun:grin:
Mercedes make a removal tool, but too expensive for a once off job, cutting is the only way
