onefortheroad
- Dec 8, 2015
- Location
- uk.
- Me -2019 GLC 350 coupe AMG line. Mrs- ford kuga 65 plate awd powershift .
Im just after sorting a DPF problem on my OM651 Vito. Your DPF pressure is good as mine is 1.2 bar at tick over after DPF off for a DIY deep clean. check injectors (running smoothness of Cylinder on my icarsoft) It will give you an idea if an injector is over fuelling? and possible filling DPF as was the case with mine. When my DPF was full @ 230% the back pressure at tickover was 1.11 bar. Have you any fault codes relating to injectors (teach in parameter codes etc?)
The 1.11 bar is exhaust back pressure sensor at the egr. The dpf sensor should read minus 0.04 to plus 0.04 . 2 very different sensors .
