E220d (oil in brake servo) £5600 bill for repairs
JBell
Torquey
C350 CDi Estate (GAD Edition)
This is truly appaling!!!! Terrible service and shocking longevity on parts!!!!!!
Jim2
Still many out there. An acquaintance of mine has a 520d which decided to pack in on the motorway just before Christmas. Timing chain. N47 engine. £800 to fix and they got off lightly!
Up to very recently here in Ireland, BMW were either doing engine replacements, where the chain had actually destroyed the engine, to pre-emptive repairs, replacing the chain, tensioners and timing gears. The local BMW dealership, were working flat out doing warranty work on these N47 520 engines.
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
I can understand why dealer groups are investing so heavily in the used 'car supermarket' market, they must be sick and tired flying the flag for their marquees to spend so much time dealing with poor design and manufacturing problems and keep customers happy. I know a couple of master tech's for other brands and the time/funds they are allocated for the recall and warranty work rarely equals the time and effort actually taken, which then equates to issues from rushed jobs.
moj91
Northamptonshire
Update: as it is relevant to the OP - i have reported the brake failure element of my incident to VOSA, they have quickly come back to me and i have offered them a detailed account of my experience. They have also assigned an engineer to my 'case' and told me that it appears to be under the same circumstances as a number of other reports they have had. They tell me they are in discussion with Mercedes UK due to the safety criticality element. Fingers crossed for a full recall, which may assist the OP from a financial standpoint if they are not successful with a goodwill claim.
OP - if you read this, make sure you file your own VOSA report. It will help you and everyone else if this matter needs to escalate.
barian
Woking
S213 E220d
Can anyone who is suitably knowledgeable advise how this failure, with the resulting loss of servo assistance, affects the operation of the automatic emergency braking (i.e collision avoidance/mitigation) systems? Will these experience reduced performance or will full braking still be achieved?
If the servo is compromised then the emergency breaking will also be affected as it uses the same braking system. It just uses a different system to activate it (radar from the front grill rather than the drivers foot)
Jim2
I can understand the brake servos being out of commission for one reason or another, but should not the manual function still be active? Albeit with a much harder effort required?
It will be, but it will feel like you’ve no brakes at all, standing on wood if you will
Jim2
Yes, I can imagine, especially with disc brakes,whatever about drum brakes .
Jason63
C63 AMG
I bet the vacuum pump is made by an OEM manufacturer and bought in by MB.
Now...BMW had a major recall on vacuum pumps on at least E60/E61 petrol 5 series. The same failure: the vacuum pumps failed, oil gets into the vacuum system and deteriorates the rubber diaphragm in the brake servo. The result is a loss of all braking assistance. In theory the brakes could be operated with additional pressure but in reality it was like having no brakes.
BMW managed to hush it up and the recall, was I think, only in the USA despite identical engines here in the UK. They also managed to restrict the recall to petrol engines - yet the exact same setup and failure was also seen in diesels.
I would hazard a guess MB use the same vacuum pump supplier.
moj91
Northamptonshire
Trust me, stopping from 55 over approx 200m was hard enough!!
moj91
Northamptonshire
I wouldn't be surprised. Most components are outsourced, arent they.
Further damage is my main concern. Its ok them replacing the pump and nearby lines, but if they just decide the servo is fine and don't replace it, then it fails say 2 years down the line, its out of warranty and at my cost. Of course anything can fail out of warranty, but this is somewhat of a 'known'.
MB usually are pretty good at replacing EVERYTHING that could possibly be affected (at least all quotes I have seen)
plunkett cassidy
New Registration
2018 e220d
HI, I have a 2018 MB E220. I have a similar issue oil in the brake servo and a estimated cost of 6000 euro. I have had a lot of problems with this car i.e sensor and oil leaks. Any advise?
oigle
members.optusnet.com.au
Gazwould
C250 CDI
I would of thought this will become a recall as it's to do with the brakes .
It's apalling , so called Premium quality .
It's not over yet for your 654 has another achilies heal .
Rub hard a Mercedes badge and look what's underneath !
star
Reading
Smart + others :)
We have seen timing chains fail on the 654 engine @ 140k miles, no warning, no rattle unlike the 651 engine. We are saying to our customers to get it changed with mileages over 130,000 miles.
We replace the timing chain as part of a camshaft job.
Jim2
Not heard anything yet....
And I was thinking at least MB don't have inbuilt design problems like BMW's N47 timing chain's falling apart
