deejaybee
- Oct 21, 2006
- Location
- Surbiton, Surrey
- Now - W210 E320cdi
Have recently aquired a '93 E220TE. It has ''only'' done 120K miles and is in quite good shape for the price I paid.
When I bought the car it had the ''hunting'' problem which seems common with these. After changing the oil, filters, plugs and cleaning the MAF and throttle body this seemed to cure the hunting problem but then the idle speed increased up to about 1100rpm. I found that the throttle cable adjuster had been screwed right out (presume to stop it stalling) and I re-adjusted this to what semed a more reasonable level.
Currently the idle speed when warm is about 800rpm in N/P and drops to about 600rpm in D. Also it starts on the key when cold and idles at about 1200rpm (which I think is right), but it quickly drops after about 10-20 seconds and will stop unless you give it throttle. This means the car is difficult to drive straight away unless you let the engine run for about 1-2 minutes keeping the revs up with the throttle. Once it has warmed up a bit it is fine, even through the revs drop right down to 500rpm in D until it has thoroughly warmed up.
This presumeably must just be some aspect of cold running control? But not sure if this would be ECU related or anything else. Any advise would be appreciated.
regards,
Dave
regards,
Dave
