matthillier
- Feb 3, 2008
I need some help.
My car has developed a fault which I hve taken to the local garage but they have drawn blanks in all directions.
They have put it on a diagnostic computer and trouble shooting computer without any results.
The problem started when I used the kick down to overtake a vehicle. As the engine revved the gear box changed down gears however it didn't seem to engage properly and the car started to crawl rather than pull away....as if in the wrong gear.
Since then the car struggles to pull way properly...the revs increase however the car simply crawls even when the revs are right up high....it will then gradually pick up up speed and pull away....again alsmost as if it is in the wrong gear.
On a number of occassions the car has almsot stalled...definately not right for a automatic.!
The car will comfortably cruise at 70/80mph however as soon as I accelerate to increase it again feels as though it has selected the wrong gear.
I seem to have an increased petrol consumption...however I put this down to needing to rev so dam much to get going.
The garage have changed the plugs(were needed) but no change and they have checked the cat as well as the diagnostic machine...they have now told me that they have drawn a blank.
I need some help, is it possible that their computer is not fully compatible with the car???
All replies I thank you for. Regards
