e240 v6 whats this noise please??
dieselonly
york
w163 320, previously w210, e240 estate, w124 300, w123 300td w123 240td c220cdi w210 240 w210 300td
hello
my 99 e240 v6 estate has recently started to make a noise, it difficult to describe/diagnose like this I know but will have a try!
it appears to be coming through the middle area of the car, back of engine through central vents etc. the sound is a kind of whine but can also sound a bit like when a worn to metal brake pad is scraping against a disk, it isnt! most pronounced accelerating at low speed & even more so when letting off the throttle from a higher speed, it will also do it when slowing down & in neutral. my immediate though was prop or transmission, but in neutral??
that do you think?
I know on the 203 the the parking brake cables and heat shields can come away and touch the prop shaft,,One a 202 it could just be a heat shield, and these are easily put back with self tapping screws
The Hooded Claw
My old 202 did that ............as Malc says it's the Heat shield DEFFO!!!!!
D
dieselonly
york
a screw had come through the heat shield, replaced with addittion of large washer. still making the noise, so probably not this.
