e250 Heater Problem - No blowing power
irishphoenix
Hello All,
Second post here and I'm sure there may be other folk with the same issue as me. I have a 1996 e250 and the heater works and the fan blows. Its a manual knob system but when I turn it up to full power there isn't much of an increase in the amount of air, cold or hot, blown into the car. As a result getting a lot of steamy windows when more than one person in the car. Is this a fuse issue or something? Not very technical.
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
make sure to check your pollen filter, its located usually at the footwell area in the drivers side
cheers
anyweb
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Agree that a blocked pollen filter is the most likely cause of your problem, this link will show you how to find the filter I think it's similar for you car ;http://202tech.mkosonen.com/howto/blower.html .
Make sure you cover you carpet before removing anything as there is likely to be a lot of dirt in there.
