E270 cdi Automatic Gearbox Problem
jangers7
Hi everyone,
I am looking for a bit of advise regarding a problem i am experiencing with the gearbox.
When accelerating from between 40 - 60 mph, the rear of the car begins vibrating (shuddering) :confused: .
I have been advised that there may be a problem with the gearbox colling system and the coolant may be leaking into the transmission oil.
Any advice on this matter would be greatly appreciated
Thanks :D
First thing is that you do not drive the car until you know if the radiator has split. since the water operates at a higher presure than the oil cooler the water level should have gone down.
If you have a dip stick for the gearbox the water could be seen, but the chances are that you do not have one, and that means draining the box.
This must be the most stupid arrangment since the invention of the motor car
Malcolm
jangers7
Thanks for that!
is that the main radiator or is there is there a separate one? If the radiator has split, is it costly to repair?
psmart
Television was indicating that there is a design 'bodge' on these cars, where the radiator for cooling the water is merged with the cooling of the autobox fluid. If the radiator springs a leak, it pumps pressurised water into your gearbox... no oil, no lubrication, gearbox goes to its makers!
There are a few threads on this problem, just do a quick search.
Just to add... on my MG Montego Turbo, the Turbo was water cooled, and after the first engine blew up, it was replaced by 3 successive gold seal engines, only on the third engine did they find the micro crack in the Turbo - result was that when the Turbo spun up, it would pressurise the water system and water would come out wherever it could, primarily from the header tank! Just goes to show can happen in 'shared' systems!
anapolis
Cyprus , Limassol
E270 , 2003 , W211
E270 Mercedes slip proplems and vibration
hi i have the same proplem with my gearbox there is no water cooland in the oil but when it change gears there is a tremor from the rear of the car only on hi gear please help , its like a slip of the gearbox
sorry i don't unterstand your answer
The symptoms of glycol in the gearbox are.
When pulling lightly in top gear at engine RPM of between 1500 and 2500 a humming or droning.
You cannot see in the fluid if there is any glycol content.
V6Matty
Newark, Nottinghamshire
about £60 at an indy for a glyco test, all you need to do it send them about 100ml of your ATF and they will check it, takes about 30 minutes to get the results IIRC
Thats quicker than the NHS :rolleyes:;)
Dannyboy201062
Dublin, Ireland
2002 C270
My pal has a an E270 CDI Auto ........used to shudder in the back when decreasing speed , he was worried about the transmission......He later then got a blocked CAT. He got the CAT removed and replaced with a pipe..........shuddering stopped.
Regards..............Dannyboy
markg14
Essex
C-Class Sport C220 CDI 2007
Hi everyone,
Thanks :D
I think you may find that as a result, the torque converter will be knackered and need replacing.
It is the knackered torque converter that is causing the vibration.
Dannyboy201062
Dublin, Ireland
2002 C270
Blocked cat ?
See post........blocked cat , then loud bang......on my pals E270 CDI.
Before it got to this stage he noticed a shudder from the rear when changing gear ( auto ).......it developed into a limp mode problem and the blocked cat. When the CAT was replaced with straight exhaust pipe....the shuddering problem disappeared also..
Regards.............dannyboy:confused:
ssrli
Romania
Jeep GC 2002 2.7CRD
Since we're on the subject of glycol contamination...
Why not install a simple oil cooler instead of the in-radiator oil cooler? Assuming it can be covered in winter so that is does not run too cold.
