e300 td crossmember
ebony266
manchester
E300 W210
:confused:hi guys anyone help ? the crossmember just infront of the sump (the one where the bottom of the suspension arms are linked ???) looks like it only has a bolt either side . need to replace mine usual 210 RUST !! any advice anyone T I A kev (ebony 266 )
Ellsy Tanners
Mars
Quite a involved job, reqiures engine supporting and suspension dismantleling, definenatly a garage job i am afriad.
go to a good indie in your area.
ebony266
ebony266
manchester
E300 W210
:-? oh so noboby has this as a diy link then ???? not even parrot
Ellsy Tanners
Mars
I would be supprised as it not that easy without good garage eqiupment!!!!
hope you get it sorted!
ebony266
ebony266
manchester
E300 W210
ok thanks any idea of a price??
robs-mbz
Newcastle under Lyme
1997 E300TD
If the rot isn't too serious, ie just the bottom of the cross member has gone (which is usually the case) I would get it cut away and a new bottom welded in, I'm sure I've read somewhere that a repair section is available, if not its just a flat plate that could easily be fabricated. To replace the cross member completely is a horrendous job that involves supporting the engine and chassis legs with a special jig.
Parrot of Doom
Manchester
Is it surface rust, or rusting through?
As mentioned, they can be repaired in-situ.
ebony266
ebony266
manchester
E300 W210
this is well shot it will have to be replaced
robs-mbz
1997 E300TD
If the cross member is that bad then I would have a serious look at the front spring upper mounts (perches), chances are they will be rotten too, the consequences if they fail can be dramatic!
ebony266
ebony266
manchester
E300 W210
no thay seam to be ok , just the sus cross member , pitty looks like an easy diy ??? oh well will ask my indi post his reply soon thanks to all for your help and support :p;)
ebony266
ebony266
manchester
E300 W210
no they (oops) seam to be ok , just the sus cross member , pitty looks like an easy diy ??? oh well will ask my indi post his reply soon thanks to all for your help and support :p;)
