E300TD Glow plug problem
minijohn
No1 glow plug on my 97 E300TD is turning but not unscrewing from the head. It's just as far down as all the others (i.e. it's not unscrewed at all)
If I put it back together , will the plug blow out of the head or do i need to get it sorted properly
Thanks in advance
John
simon_wall69
Stone, Staffordshire
Unlikely to blow out, I drove around in my old e300 with a couple of snapped glow plugs in it, but I didn't value the car much as it was very high mileage. The glow plugs are often a problem with the 606 engine, if you do a search on here you will come up with plenty of threads about them.
turbopete
Spennymoor
2022 '71' Ford Grand Tourneo Connect (sorry)
if its turning it sounds like its stripped the threads in the head, in which case its possible it could blow out! if it were mine, id avoid using it and get it sorted properly. as Simon stated above, this engine is known for having plugs seize in, snap etc.
Number_Cruncher
1995 W124 E300D TE
They usually snap between the threads and the hex - the threads will almost certainly be in place.
turbopete
Spennymoor
now ive re-read the op description, youre quite right Number Cruncher and Simon! my humble apologies! i thought the whole thing was turning in the head! :Oops::Oops::Oops:
230K
Belfast
E300TD/1998/3.0 Diesel
My advice would be drive away at it, If it ops out just replace it.
230K
M
minijohn
thanks
Hi Guys
Thanks for the replies.
I think I'll leave it as it is & just see what happens. I can't help thinking that if it's jammed enough to snap the plug or strip the threads then it's not going to blow out when it's running. Even if it does, I'm no worse off than I am now !!
I'll just make sure my breakdown recovery is paid up to date ...:)
John
exeng
easy way to check if its snapped is to hold the hex head and if it turns and the top of the plug does not it is snapped
