E320 2000 model, outside temperature senor
josewick
A friend of mine has this E class and I must admit, sweet and smooth.
However, the sensor that reads the outside temperature sensor seems to be sensing the temperature in the engine bay, as its ready rather hi, say 40 - 50 most times.
CAn someone tell me where it is? so I can see if its fallen out or dodgy connection?
Joe
roofless
w124 e220 estate
mine is ok when i start the car but within a min or two it reads very low ? is it a replace it job with a new part or is a quick fix known
Its normally the sensor
J
josewick
i will take a look. Thanks
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
On the blank black plastic panel inboard of the passenger side foglight there should be a little probe sticking out, like a pin. it can get dislodged causing the problem you mention, particularly if you often park front into grassy areas. If you ar elucky its a matter of resetting it. Happened mine like that.
