E320 cdi charging fault?
Jonny2tanx
Last week the BAS warning light came up on my 2000 E320cdi estate just a couple of miles before I reached home after a 160 mile trip. It was quickly joined by the ABS light, the ESP light and the SRS light. I pulled up to try the lock to lock cure , but that didnt work, so I switched the engine off to see if that reset the lights. Big mistake! The car wouldnt restart at all so I had a nice walk home. Went back in the girlfriends car to jump start it, and lo and behold my car started so I drove it home with no problem. Following morning, started to drive to work (lights and heater fan on), and the Xmas tree dashboard lit up again. Turned round and went back home and the car died completely just as I got home. I charged the battery and the car ran fine the following day, during the day, but failed again, handily when my girlfriend was out in the car in the evening. RAC man came out and said there was no output from the alternator. I see the alternators are stupid money but can get a remanufactured unit for about £200. Is it a DIY job to change the alternator, or do I need to book the car in to my local Indie to sort out? Naturally I could do with saving as much dosh as I can at this time of year else there will be no Xmas pressies for the gf and kids.
Xtractorfan
S class
Alternator may only need a service pack, what mileage you got?
Is the car a 210 or 211 and the year please
Jonny2tanx
The car has done 151,000 miles and has full service history
Jonny2tanx
Its a December 2000 W210 estate - just celebrated its 8th birthday
I am checking now to see if I can find any info on a brush pack
Jonny2tanx
Thanks Malcolm. Much appreciated
There is nothing given for changing anything on it.
A Bosch service center would know,
I do have the remove and refit info if you would like it
Jonny2tanx
Thanks Malcolm. I'll give them a try. The remove and refit info would be much appreciated.
Its sent,, please go back and remove address in "edit" in your last post
Jonny2tanx
Thanks Malcolm. Looks like fun! I'll have a go at it this weekend.
www.W140.co.uk&www.r129.co
