E320 CDI estate 54 W211 Suspension
REVILLP
E320 CDI Estate '54 every extra, A140L '53 no extras, A180 CDI 09
Got back in car after a short drive and "Visit Workshop" warning that shows an outline of the vehicle with an arrow in the middle pointing up appears on dash...does anyone known what it means. Car has airmatic suspension. Suspension / drive feels ok...using the switch that shows an outline of the vehicle with an arrow in the middle pointing up raises the suspension...never used this switch before. Thanks everyone...
Need some fault codes, going be the pump is not making enough pressure due to being burnt out or a axle level sensor...............
R
REVILLP
Is it ok to drive
Is it ok to drive...if it is the pump or sensor any idea of parts /labour costs might be ... Car has 162k miles on the clock Thanks
Pump is around £400 but don't quote me on that price, you would need a relay as well, the level sensor might just need a modded bit of wiring. safe to drive until It packs up completely and she sits her ars on the ground.........
R
REVILLP
Just had a closer look at the car and it appears to be sitting a lot higher than previously...especially at the front...also when 'the button with an image of the car and an upright arrow ' is pressed nothing happens...previously this highered the car I think...does this fit in with the pump failure concept????
On all these systems the height controls never work when the warning is on
R
REVILLP
Car due for service in 4 weeks time...so will get it checked then....will it be ok to drive until then and not cause any other damage....thanks
R
REVILLP
All fixed, was 2 * cable harness that was needed (£2.35p ea) + diagnostics + labour...so good resuilt. Thanks
