kiwi_bloke
Hi guys.
Have the following.
Car had head gasket replaced.
It now surges 300 rpm while coasting when warm (never cold).
Rough idle between 60C and 80C - ok when hot (most of the time).
Surges when coasting to a stop.
Originally had the code "MAF at lower limit". So replaced the MAF. Codes Cleared.
Now have "MAF at lower limit", MAF at upper limit", "Lambda at upper limit", "Lambda out of range".
Does this mean I now need an o2 sensor? Running got worse after the MAF, mostly in the 60 C 80C range - but tidied up when hot.
Where are the O2 sensors in this chassis?
Oh yeah, its a 1996
Have the following.
Oh yeah, its a 1996
