Very interesting looking back through many of the past topics and threads.I've learn't a fair bit allready about future problems I might encounter!
My E320cdi 2000 81,000miles has a intermittent starting problem.Glow light comes on and goes out as normall and if the car doesn't start on the first attempt straight away it takes 20 seconds turning the engine over on the second attempt.
Theres also a problem when you accelerate quickly the ECU shows a code EPC
and this holds the engine back from acelerating or going down the box.The car has had diagnostic check and this shows no obvious faults, engine or gearbox.They replaced all glow plugs and air mass sensor.Could it be a faulty injector and would this be the cause of both problems?
I would really appreciate advise before I pass it to a main dealer.
