E320cdi avantgarde fuel pump problems
Eilidh
E320cdi avantgarde
Hi,bought a 2nd hand merc drove fine till one morning wouldnt start,garage says the can fill fuel fiter and get car running but its notrefilling, is this the fuel sender in tank or the pump,any help would be greatly appreciated
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome
So the garage are priming the fuel filter but still not starting? Was there no fuel (Diesel) in the tank at all when it didn’t start?
E
Eilidh
E320cdi avantgarde
Welcome
Hi they filled the filter manually ithink,its seems to not be drawing fuel from tank,not sure if its the sender unit or the fuel pump,could you tell me the location of low pressure pump?is it under the rear passenger side?
E
Eilidh
E320cdi avantgarde
Sorry firgot to say,diesel in tank only a few gallons
E
Eilidh
E320cdi avantgarde
Also forgot to ask are their two fuel pumps? Is there an inline pump undercar also i was told their is another pump on engine
E
Eilidh
E320cdi avantgarde
Its a 2001 y reg 3.2 estate
malcolm E53 AMG
The low pressure fuel pump sits with the high pressure pump at the front of the engine and pulls fuel from the fuel filter. All the low pressure lines are plastic with ‘O’ ring seals which harden/perish over time and allow air into the lines. If the garage has changed the filter they can require quite a bit of cranking to prime the system
E
Eilidh
E320cdi avantgarde
The garage put a new filter on,still same issue ,he can fill filter and run car but filter runs dry,hes told me to buy an inline fuel pump as he thinks thats the problem,am thinking of buying new lines and orings aswell just to be sure
E
Eilidh
E320cdi avantgarde
Can i ask does it have an inline fuel pump aswell?
mersum1es
Finland
aux pump is only next to hp pump like said. If you see air bubbles in clear hoses, it is most likely due to o-rings or brittle hoses.
E
Eilidh
E320cdi avantgarde
Does the low pressure pump supply diesel to the fuel filter?
As Malcom said a few posts above:
"The low pressure fuel pump sits with the high pressure pump at the front of the engine and pulls fuel from the fuel filter."
It doesn't supply fuel under pressure to the filter - it obtains filtered fuel from the filter.
E
Eilidh
E320cdi avantgarde
So where is the pump that supplies diesel to the filter
Here's the diagram of the fuel system:
And the tank:
There is no pump at the rear of the car hence you should not need an inline pump (thats a bodge to get around the real issue).
There is a fuel strainer in the tank ( part number A1104700486) which is just visible in the bottom of the picture. If that is blocked you won't get fuel delivery.
If you have air leaks anywhere in the lines you won't get fuel delivery.
If you have a crushed/damaged line you won't get fuel delivery.
If your fuel cap vent is blocked you won't get fuel delivery.
Try those things first. Adding a pump where one shouldn't be will mean tapping into the loom, tapping into the fuel lines and finding a place to mount the pump (and it may not fix it).
E
Eilidh
E320cdi avantgarde
Ok thanks,will need to go back to garage and try to get to bottom of it,as they ssid theyve ordered an inline fuel pump that fits under rear passenger side next to a fuel filter
malcolm E53 AMG
Make sure there is a good amount of fuel in the tank to add a bit more pressure and as said they do take a while to crank, if this doesn’t work connect a booster to the battery but make sure you don’t overheat the starter.
If all else fails try a hand primer
Does the garage have experience with this model changing the filter and priming the system can be problematic as all MB garages and specialists know?
I wouldn’t entertain an in-line pump, totally unneccary, and not the soltion to the problem, if you can’t prime by hand you have a blockage
E
Eilidh
E320cdi avantgarde
  • #18
Ok thanks forhelp,will be down first thing in morning,and no they are not mb specialists,its a local garage very well reputed who usually buil high performance cars for rallying and boy racers
That will mean they will be well versed in petrol engines but probably not so up on diesels.
om613
london
S202 C250TD, S123 240TD
Steve and I would use 'Easi-start'.
After replacing the pipes' O rings.
Priming is not easy.
Your garage don't know what their doing.
