e350 cgi 2010 check engine
Dany Al Khoury
e350 2010 aventgrade German
hello. I have a problem noone is able to fix. while driving my car starts lacking acceleration .it starts to break down and then the check engine pops up. i put it on the scanner it showed fault as .(the rail pressure is too high) No-1141. If i leave the car for a couple of hours and then drive it the check engine is still on but the car doesnt break down . sometimes if i leave it till next day or if i am standing in a down position and leave it for a couple of minutes . the check engine turns of. I have a e350 2010 mercedes aventgrade german car. someone told me the High pressure pump is not good. But if the high pressure isnt good it should not start the car at all . Please help me if possible. Thank you
Looks like a generic phone based app - try reading with a Mercedes specific code reader as the definition may vary from the generic.
D
Dany Al Khoury
I used different scanners on the car. all showed the same fault
When it's in a failed state check the live values of the crank sensor and fuel rail pressure.
D
Dany Al Khoury
i checked the fuel pressure . It was good.
D
Dany Al Khoury
hello my e350 2010 cgi is turning the check engine on . i tested it tbe scanner showed (the rail pressure is too high). i tried to change the high pressure pump but the car still had the same problem . when i drive it the car doesnt take gas . when the rpm between 0-2 . sometimes above 2 the car drives normally. it takes so much time to turn on too. any help please noone is able to fix my car. Thank you
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome, where are you based please?
